Engines and Emissions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Benzoate, Jun 12, 2000.
  1. Benzoate
    Benzoate Registered Member
    Jun 5, 2000
    20
    Ok, if you replace your engine with a new model that's fuel injected and runs cleaner than a 15 yrold carbed one, will it pass inspection because it's not 'origional equipment'? And what is the definition of a 'crate engine'? Does it have all the accesory pumps, starter, alternator, etc? Or is it just a block and you add the extras?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Usually a crate engine has the bottom end and the top end done. You have to supply the ingition, fuel system, cooling system, electrical system and the brackets.
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    My limited understanding of the rules for most states is that swapping a newer motor into an older vehicle is legal, <font color=blue>AS LONG AS THE EMISSIONS EQUIPMENT REQUIRED FOR THE NEWER MOTOR IS USED.<font color=black> It's difficult for me or others to give a better answer since your profile is blank, but that's your choice. No one here will hold your desire for privacy against you. Your best bet would be to find a good inspection station and ask some discrete questions. If you're in CA, be prepared for a paperwork nightmare.
    [​IMG] Semper Maintenance!
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    All the info you could ask for about crate motors can be found at <font color=blue>http://www.paceparts.com<font color=black>
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
