engines?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by shaun, Oct 15, 2003.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I have just purchased myself a 3/4 ton parts truck for my 71. But I still have no engine. I am putting the 327 out of the blazer into a camaro so now I need one for my blazer. I am choosing between an olds 455, caddy 500, or chevy 427. I want fuel injection so I think my choice will be a 427. It will be new but it is a 69 corvette motor. What do you think. Do they make fuel injection for a 455 or 500. Also I know that greg 72 has a 427. What is that engine from? And what is your opinion of it? Also what is your gas mileage. Its not important I am just curious. /forums/images/graemlins/ears.gif
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    The 472 is probably a Caddy motor. Basically the same as a Caddy 500 except for the crank and pistons.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Greg actually has a 396BBC if I remember properly??
    I belive any SBC Fi will work on any SBC and any BBC FI will work on any BBC block, with the proper heads of coarse.
    Myself I am going with a crate engine probly RamJet 350..
    good luck
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You can fuel inject any motor you want. Cheaper and easier would be to use the Chevy block.
    A Vette 427? If original, to much compression for your needs probably. I would search around if anybody really needs that motor for their restoration. You might make enough money off that to pick up a new 502 motor.
    Nothing wrong with any of those choices, they can all be made to work....
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    The 427 is your best bet.parts are easy to come by.Check the compression ratio,you might have to run higher octane gas though. The power and torque will be worth it!
