Epoxy, JB Weld? What should I use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RaisedK5, Jul 5, 2000.
  1. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    This isn't actually a truck question but hey you guys know everything. My other ride is a 69 Buick Riviera, and somewhere along the line some Jacka$$ overtightened the fuel filter holder thingy on the front of the carb and stripped it out, now it leaks. The carb is in great shape otherwise so i figured the easiest way to fix it was to put in an external filter and glue the inlet fitting in , so my question is what should i use that is not affected by gas? And by the way i wish i had that engine in my Blazer, woohoo, 360hp & 475 ft.lb. thing drives like a rocket ship, anyway, any help will be appreciated.
    RaisedK5
    "Friends don't let friends drive Fords"
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think you can have the thread rethreaded one size larger with a special tool and simply change the fitting.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    You might just want to try a bunch of wraps of teflon tape and see if that seals it up. I wouldn't bother trying to use any kind of epoxy or other sealant right there, the consequences are too grave if you have a leak afterwards.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The label on my box of JB Weld says that it can be used to repair gas tanks. I'm thinking this means that gas won't mess with it. [​IMG]
    http://ThunderTruck.ColoradoK5.com
  5. Cua757
    Cua757 Registered Member
    Jun 4, 2000
    30
    Edmonton, Alberta
    Have you tried tapping it out using a tap and die kit yet? I'm sure a heavy duty truck shop would have something that would work on a thread fastener that size. (If you Tap it out, clean your carb completely!)
    Ever Been Dirty Rotten Filthy Stinkin' Stuck?
  6. RaisedK5
    932
    Long Beach, CA
    i ended up using the JB weld, no leaks, the threads were really messed up so teflon wasn't an option, and i was trying to fix it cheap, so a huge tap wasn't really in the cards either, but thanks to everyone anyway!
    RaisedK5
  7. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    you should try bringing it to a local machine shop to se if they can re thread it or even heli coil it the shop i work in may be able to do it if you live in connecticut
  8. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    if its a holley get another float bowl. JS
