epoxy on carb ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, May 16, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok went to pull the hose for the dis and check the timing and guess what pulls out too ???
    The damm fitting to that the hose is to attach to at the base of the carb...Now can I get some epoxy and "glue it" or am I looking at taking the carb off and getting a new base some how....thanks ...mike
  2. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Epoxy will be fine. I've had this happen before and just use a tiny bit of epoxy around the metal tube and stick it back in. When rebuilding quadrajets you have to epoxy over the caps for the casting wells inside the carb, it's resistant to gas and heat so you'll be fine.
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    kewl thaks that's what I thought but want a 2nd opinion.....mike
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Next to females JB Weld is the greastest thing on earth.
    John
