EPR Valve
Discussion in '1982-Present GM Diesel' started by Tybee, Oct 20, 2001.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Found a disconnected vacuum line and it goes to the EPR valve (not EGR) where is the located?
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    It opens a butterfly valve on the drivers side exhaust manifold that creates more backpressure which forces some more of the exhaust towards the EGR valve. When its activated it closes partially and when off it opens all the way. Id leave it disconnected and plug the line unless youre worried about emissions. If so, make sure it and the EGR are plugged in and operable.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thank you, and I did plug it.
