EQUAL or SUGAR
Discussion in 'The Garage' started by hawkeye649, Oct 14, 2004.
  1. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
  2. mrk5
    Apr 20, 2004
    12,329
    1,032
    Northern Colorado
    Try a search.
    The biggest complaint I've read about is that it clumps up something fierce when exposed to moisture.
    So, if you plan to use CO2; definitely don't use equal.
  3. terky
    terky Registered Member
    Aug 21, 2004
    24
    Arlington, WA
    I forgot what kind of rig it was on but a guy put BBs in his tires, i think they were 40s, somewhere around there. Then to combat the clumping when it got icy he put some straight antifreeze in there to slosh around.
    He said it worked really good. I will see if i can still
    find the site.
    EDIT: it was on pirate, Tires: Michellin XML Military Radials 325/85/R16, heavily grooved, I guess he didnt put antifreeze in there.
    http://www.pirate4x4.com/tech/billavista/Beadlocks/Beadlocks.htm
  4. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    My frient mounted my 92 lb Baja Claws and used equal but he almoust had to use golf balls no kidding. He mounts tires for a living /forums/images/graemlins/thinking.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've heard of (Never tried myself) people putting golf balls in thier tires. Don't really know what too think of that one.
  6. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i used equal on my 37's and it cleared up any problems they had, i say get it if you currently have problems, but if not try without.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've never had anything on my 38.5" TSLs
  8. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Try a search.
    I want to hear from someone who has actually used
    equal that has had it clump up on them. I have talked to a rep and they say there is no way it can due to it not being a soluable product. I have it in my front tires but have never broke the bead to check the condition.
  9. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I put Equal in six 35" SSRs on my dually about 2 weeks ago. It's been on the road and freeway a few times since and no vibration so far. 4WPW swears by it ... if that means anything to you!
    Eric M.
  10. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    here are a few old threads touching on this subject
    Thread 1
    Thread 2
    enjoy /forums/images/graemlins/wink.gif
    /forums/images/graemlins/burb.gif
  11. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I run golf balls in my TSL's. It works great. Ill never pay to have another truck tire balanced again, ill either run BB's or golf balls.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I live in an extremely humid and rainy climate
    never clumped in my tires
    I think the clumping story is total BS
    it did turn greyish after a year from the rubber residue
  13. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    only problem with golf balls...is I hear it will eat up yer tire (no BIG problem with something like a swamper) but they will also dent up yer rim...in case you have a good set of wheels you care about /forums/images/graemlins/thumb.gif
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run equal in my irok's and it works great i also ran it in my swamper's and worked great in that as well
  15. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have it in my 38s, 42s and my buddies 38s. It does work. What size tires? They take differrent amounts.
  16. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    For a 38.5/14.5/15 they told me (customer service) I needed like a bag and a half for each wheel. I put 2 bags in each, I still need to break the bead on the rears and put it in.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    some stores have an installer that blows it in the valve stem
    seems odd as they try and sell you valve stems with built in filters that would preclude the use of the installer tool
  18. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    ?? what do you meen preclude the use of the installer tool?? I never did put the valves in, They included fat little yellow O ring too. What is that for?? When I air down I dont like waiting I always pull the valve out.
  19. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the o-ring is for you to put on each valve stem so that the tire shop knows that there is equal inside so he doesn't get a face full of it when he takes the tire off the rim
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the installer tool is basically a chamber that allows the equal to be blown into the tire through the valve stem
    the valve stems they recommend to use with equal have a sintered brass filter to prevent Equal from getting into the valve core
    http://www.imiproducts.com/equal/accessories/index.aspx
