evap emission control system leak
Discussion in 'The Garage' started by 90K5, Apr 6, 2007.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Got a check engine code PO442, says a small leak exists in the evaporative emission control system...anyone had this problem, ideas whereto start looking? Truck is an 01 silverado with the 4.3
  2. shadow6000
    shadow6000 1/2 ton status
    Jan 2, 2006
    126
    North Wilkesboro, NC
    Check your gas cap. You may not have gotten it back on tight at your last fuel stop.
  3. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    could also be evap purge solenoid, i replace a lot of those at work. takes less than 5 min to do.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check your vaccum lines also.
