even more flip questions....
Discussion in 'OffRoad Design' started by hi pinion, Feb 17, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    hi.i have an 85 k-5(1/2 ton),in witch ill put a hp d60,and a 14 bolt.you offer 2 different shackle kits for the rear.....a 1/2 ton and 1 ton.will the 1 ton kit fit on the 1/2 ton,if im putting on 1 ton axles????what about the front?will your 1 ton front shackle kit (and frame mounts)work on a 1/2 ton frame,with a dana 60 up front???(hp)??just curious if its ok to "mix and match"...thanks man,hi pinion
    /forums/images/graemlins/thumb.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    1 tons have a different spring width, namely where on the axle they mount, thats why there is a seperate 1 ton flip it has to have different measurements. So no it won't work on your 1/2 ton frame, front axle has no bearing /forums/images/graemlins/wink.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, you need the standard 1/2T or 3/4T flip and you'll have to move the spring perches on the axle to 42.5" center to center.
    The D60 front will bolt to whatever you have in the front, they bolt up just like the 10 bolt/D44.
  4. hi pinion
    Sep 25, 2003
    5,354
    Ok ,thanks guys,so to make a long qestion short,the front shackles you sell,will work on either 1/2 ton and 1 ton trucks,right??Theres only one front shackle kit you sell(and frame mounts)and it is a universal kit,right?again,thank you,Jake /forums/images/graemlins/thumb.gif
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, HD front shackles are all the same.
