Ever broken a body mount?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Feb 26, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I was flexing VERY hard when my front right (under the radiator support) broke. The washer beneath the rubber mount broke in the center. The washer was VERY rusted up top, but not at all below. Now it looks like a doughnut. Anybody ever had this happen?
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    4 of them now I have poly mounts and regular heavy washers instead of the gm washers
    <font color=red>Let me at it I can break it</font color=red>
  3. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Well, good thing is those mounts up front (radiator) are the easiest to replace
    "Whatever happened to my Rock N Roll?"
    IM nOt wEiRd, i jUsT lOvE tHe sHiFt kEy!!
  4. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I'd take a look at the rear most mounts. On the burbys I've had that mount always broke. With that long of a frame (flex) and a solid tub, something has to give.
    Thank you......Detroit!
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my buddy (mudboggad) broke that one and he and i replaced it. it wasn't technically difficult just hard to do and time consuming.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    The problem is that the stud is turning with the nut. To fix it for now, I got a 3/4 head nut and a washer, put the rubber doughnut on, put the broken retainer on, then put a big washer and the new nut on...works fine for now.
