Ever have this problem with a 52" swap?
Discussion in 'The Garage' started by Art'74, Mar 20, 2006.
  1. Art'74
    Art'74 1/2 ton status
    Dec 21, 2004
    145
    OKC
    Outside in
    Inside out
    Front
    I am working on a '74 Blazer frame doing a 52" front spring swap. As you can see the bottom hangar isn't exactly snugging up to the frame. (I know I don't have all the holes drill, etc. just doing a mock up for now)
    Anyone else every have this problem?( I have searched and not seen this type scenario) If so, please advise your fix or if I am doing something wrong, straighten me out. I am all ears.
    Art
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I must say, you are the first 73-80 person I've seen do 52s... the frames kick up and are slightly different, makes me wonder if its an issue undiscussed yet.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    this isnt suprising especially since kert is having problems with his b-52 kits. i think he made his for 73-80 frame not 81-and up and had issues simialiar to this
  4. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    I did the swap on my 74 and had the same issue. I plan on milling some wedges to fill the gaps and then run the front bolt through it. The wedge will be welded to the frame.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've done it before. i was going to tweak the brackets to hug the bottom of the frame.
  6. Art'74
    Dec 21, 2004
    145
    OKC
    I didn't think I was the lone ranger on this, just never saw it discussed or shown.
    Yeah the wedge welded is an idea. I thought of a bushing type fix welded at the top and bolted thru as you suggest. Also, I am going to form some plate to fill in the frame where it U's in on the inside of the frame and weld it solid there.
    It always takes fabrication when your fabricating.
    I would love to hear Kert's input or thoughts. All of his work is top shelf and I know if he has input it would be solid.
    By the way, it can't be said enough, the folks on this forum are the best.
    Art
