Ever Thought of Making some Dana 60 Set up bearings?
Discussion in 'The Garage' started by JpEater, Sep 8, 2006.
  1. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    I am setting up an E-Locker in a Dana 60 and was thinking about using a cylinder hone to hone out the inside of a pair of carrier bearings just enough to be able to pop them off with a chisel or a screwdriver. Snug but not tight.I would do this so that they could come off easily to changes the shims to set the gear up. When I got the right shims right then press the new bearing on. Anyone have any idea if this would work?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have a set in my toolbox. Made them with a dremel
  3. muddindirty
    muddindirty Registered Member
    Aug 24, 2006
    46
    Down South Louisiana
    I have a set also but I also have a tool that I made to set the pinion depth from scratch. It consists of two plates I turned down to the exact OD of a set of carrier bearings with a 1.000" rod that the two plates press on to make a dumbell type config with a flat machined in the rod exactly .500" in the area the pinion would sit. I then drilled a .1875" hole in the center of the flat and use a depth mic to set nominal pinion depth if the original shims get misplaced and to check the original pinion depth of the pinion being taken out. It helps speed up the guess work and has really saved me some time. I think I'll market it to Snap-On or Matco:eek1: , you know how much there special tools cost, I'll be the next billionaire, yeah right!!:D
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Only problem with marketing your tool is that a pinion depth setting/checking tool has been around almost since the beginning of time. :grin:
  5. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    when i did the gears in the 10b, i used a dremil on the original bearings for set up bearings...it almost sounds like you are thinkin too deep into it. I see no reason the cylinder hone wouldn't work, but a dremil may be more simple. It only takes a min or two per bearing with a dremil.
  6. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    You have obviously never used a cylinder hone before if you think that would be more work. On top of that it will hone a perfectly round hole when a dremel won't.
  7. muddindirty
    Aug 24, 2006
    46
