Ever used a Holley TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89OKIE, Sep 18, 2001.
  1. 89OKIE
    89OKIE Registered Member
    Aug 16, 2001
    11
    I got a new TBI (Holley 502-6 670cfm) for my 89 Jimmy. I've got everything dialed in except for the pressure regulator. Holley recommends 15psi. Should I set the regulator at idle or at a specific rpm? Also, can you hook up the pressure gauge on the fuel rail after the filter, or do you have to hook it up right behind the TBI? Any help would be greatly appreciated. Thanks,
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I had one on my FJ40, And I did the reg. at idle I also put a pressure gauge just before the inlet. So I could see it.
    Hope this helps some. Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
