Everyone who's running CROSSOVER, what did you do with your X-MEBER
Discussion in 'The Garage' started by dhdescender, Nov 15, 2004.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Everyone who\'s running CROSSOVER, what did you do with your X-MEBER
    For everyone who's changed over to crossover steering, what method did you use to avoid contacting the factory engine crossmember?
    Trim it?
    Replace it with aftermarket (MOO?) ?
    Bent Draglink?
    Thanks!
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Re: Everyone who\'s running CROSSOVER, what did you do with your X-MEBER
    I ran a 4" dropped draglink with no problems.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I have ORD's highsteer with a bent draglink and have had no problems yet, although I do not have a whole bunch of travel in my 10+ year old Trailmaster springs.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sky crossover, stock crossmember, bent drag link.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Bent draglink with Ford #1104 pitman arm. It barely touches the crossmember. A little grinding will take care of it for me. I also run a steering arm spacer.
    Harley
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Bent link from ORD /forums/images/graemlins/woot.gif
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    For those running a big drop pitman arm, make sure the spring does not hit the DLE before the bump-stop can stop the axle's up travel.
    On the truggy, I built a cross member and ran a stock Ford Van pitman arm ($6 at PnP plus resize to GM DLE) with straight drag link to Avalanche arm (I do NOT recommend the AV arm!).
    On my 1 ton K5, it appears to be an after market drop pitman arm (installed by PO) but it is too low and will be hit by the spring before the bumps can stop the axle. I need to redo the cross-over with less drop in the pitman and bent link or new/modified cross member.
  8. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I run a straight Draglink and I made a new crossmember.
    /forums/images/graemlins/waytogo.gif
  9. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    MOO crossmember and ORD bent draglink.
  10. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    [​IMG] [​IMG] [​IMG]
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I run a bent drag link. It is easier on the TRE's also.
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Same, I prolly have more lift then you though.
  13. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    strait drag link,made my own x-member
  14. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    2 1/2" lift, ORD draglink, barely hits the x member when flexed hard. It might need a little grinding after this last wheelin trips findings. I've had peeps tell me I couldn't do it w/ a 2 1/2" lift but it works /forums/images/graemlins/waytogo.gif You might have tie rod to spring issues with the new knuckles. ORD sells 1/2" add a leafs as a special order for such problems. Of course I just let mine rub on the springs
  15. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    bent drag.
    j
  16. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    drop pitman arm
    bent Sky drag link
    1/2 spacer steering arm
    no mod to crossmember
    12" lift
  17. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    ORD draglink, no issues... /forums/images/graemlins/thumb.gif
  18. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    (hijack) im thinking of running crossover on my blazer. i have a 6 inch rc lift and the front is a ten bolt. what all would i have to do for cross over? i know i would need a 2wd gear box but what else? right now it turns like a tank, cant be havin that. i all /forums/images/graemlins/ears.gif thanks (hijack) sorry /forums/images/graemlins/thumb.gif
  19. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    OK,,,,I give up what's a MOO???? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  20. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    MOO
    Check out ther x member
