Everything for a TUNE UP???
Discussion in 'The Garage' started by anatomiczero, Feb 2, 2003.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    The engine hasn't had a tune up, well ever. It was put in 6 years ago. So what's everything I should change? Cap & rotor, wires, plugs, re oil K&N filter. Well the only thing i've done to it was change the fuel filter.
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    im not sure if you have an o2 sensor but if you do, change it. if your running an automatic tranny and youve never changed the fluid i would not do it now the fresh fluid will eat up the clutch packs i would also change the fuel filter again if its been a while plus all of the other things you mentioned plus maybe some fresh gear oil in the axles lube up all of you zirc fittings plus some fresh fluid for your transfer case and check over your belts and hoses hope this helps /forums/images/graemlins/thumb.gif
  3. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    Cap, rotor, plugs, oxygen sensor, clean and re oil the filter, oil change, oil filter, trans filter and new trans fluid, change front/rear diff oil and t-case oil, pcv valve, and run a bottle of GM combustion chamber cleaner thru her (before the oil change and oxygen sensor change) this works wonders, and then consider adding a fuel system additive/cleaner (this should give you 40 or 50 km more on a tank of fuel)
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    no o2 sensor because it's an 80 with a carb.
  5. schmuck
    Nov 11, 2002
    523
    just had to check had an 81 with carb and o2 sens
  6. anatomiczero
    Jun 26, 2001
    418
    Washington
    What's involved with that combustion chamber cleaner? Does it smoke a lot, what should I expect? thanks.
  7. schmuck
    Nov 11, 2002
    523
    yeah it will smoke just go to the dealership and get some top cylinder cleaner i belive thats what its called and find a vacume hose to your intake thats not big enough to kill the engine and stick it in the bottle then start her up and sit there watching it because it will try to kill the engine just like carb cleaner so you have to take the vac line out from time to time run the whole bottle through and dont bother about the smoke
