exaust Q's
Discussion in 'The Garage' started by jackedjimmy, May 20, 2002.
  1. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    exaust Q\'s
    does anyone out there run their exaust straight ou the back?
    I know that it can go out behind the tires, but i kinda need the pipes to be as straight as possible.
    I plan to run dual 3inch straight pipes with dynomaster super turbo muffs.
    any problems fitting around the gas tank?
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Re: exaust Q\'s
    Sure you can do it but you wont want to drive with the back window down. The reason most people run them with the tips coming out on the sides right behind the rear tires is cause it dissapates the exhaust fumes and alows you to drive with the rear window down and not gas yourself.
  3. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    Re: exaust Q\'s
    Mine is Single Pipe on the left side out the back and it works really well. I don't know about the right though. It doesn't gas me at all; top off, window down or what have you.
    Good Luck
    See you in moab /forums/images/icons/smile.gif
  4. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Re: exaust Q\'s
    Ive got mine running straight back. I had to run them a just outside the gas tank. I haven't had to much trouble from exhaust fumes, but I haven't had the top on yet. I can see how the fumes would get sucked inside with the top off and window open.
  5. porboy
    porboy Registered Member
    May 7, 2002
    29
    Poway Ca.
    Re: exaust Q\'s
    I used to have my exhaust out the back but it tended to get beat up on my departure angle.
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Re: exaust Q\'s
    I routed mine close to the recevier hitch so it would not get pinched into a kazoo by the rocks. The fumes come insise the cab with the window down by not with the top off. BTW it used to run out behind the tires but I could smell fumes with the rear window down
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,959
    250
    Released from Pueblo, told I belong in Southpark
    Re: exaust Q\'s
    Anybody run thiers out in front of the tires. I am about to do exhaust on mine and was pondering this very question of where to exit.
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Re: exaust Q\'s
    I am pondering chopping mine off and angling it so it exits in front of the rear tire... if kept up high it would hurt clearance... and it would keep it out of the way of suspension stuff. I already had to chop 1.5' off of mine when I put the revolvers on...
    J
