Excessive noise out of speakers at idle...
Discussion in 'Audio' started by 89GMCSuburban, Jul 25, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    When at idle, my subs hum with the engine but when the RPM's go up, it goes away. I have a Fosgate Punch 700S, true rated at 896 Watts and two 12" Fosgate HE2's in a box. I'm not currently running a capacitor.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    are you running resistor plugs in your engine? resistor plugs will help cut out the noise.
  3. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I'm using normal AC Delco plugs. I did see an RFI eliminator in JC Whitney to put in my amp power line...anyone have experience with these?
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Make sure you RCAs are not running next to your power wire and try and solve the problem without the filters first ;-)
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    1.Move the ground to a new and better spot...
    2.Almost all whine and excesive noise comes from a bad ground
    3.As said above run the rca's away from the power wire also will help but if you move the ground to a better point that should take care of the problem ....mike
    4.Take off the rca cables also and tighten the outer ring on the cables if the connections are loose that will also "pick up extra noises"
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i had probs with the wine with the engine also.run a better ground and this should eliminate all probslems
