Excessive smoking, need help
Discussion in '1982-Present GM Diesel' started by levib, Jan 4, 2006.
  1. levib
    levib Registered Member
    Aug 30, 2004
    68
    Avondale, Arizona
    I have a 87 K5 with the 6.2 in it, and on start up its started smoking a ton. It smokes less as it warms up, but still to much and a lot more than it used to. I'm not a mechanic but I can usually fix my truck and I was looking for suggestions as to what could be causing the problem, and how to check it.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Is it getting colder down there? Diesels usually smoke more when the motor is cold. As long as it is still normal after it warms up it should be fine.
  3. levib
    Aug 30, 2004
    68
    Avondale, Arizona
    Well it's a large cloud of white smoke and it comes out both sides of the dual exaust. It's not due to the cold, it was doing it when it was warmer but I didnt have time to work on it because of school so it's been in the driveway since.
  4. kennyw
    Jun 9, 2002
    13,223
    94
    ok... that sounds a little different than your first post. White smoke may be coolant/water. Have you been loosing coolant?
  5. painterbccc
    painterbccc Registered Member
    Nov 12, 2005
    47
    Tennessee
    My 1988 6.2 smokes like that sometimes. I keep eye on oil and water levels. Both stay full. I was buying fuel at big station. I started buying fuel at a small store. after about a tank of fuel at small store it had quit with light colored smoke. Was in town and needed fuel and got some at big station. Sure enough it started light color smoke. I've been wondering if they are pouring something in the diesel fuel now that it costs more than gas. I guess the joke is on us. Thinning old used oil with old cooking oil. There lets see if that will work. Look at the consumer they will buy anything.
  6. levib
    Aug 30, 2004
    68
    Avondale, Arizona
    I think I can rule out burning coolant. I've been watching and havent noticed a loss of coolant. How to I narrow it down between timing and incomplete burn?
  7. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I had the same problem.....my truck started and ran just fine, but in the mornings, it would blow a huge cloud of white smoke, and then after it was warmed up, would still smoke some. A properly running 6.2L should not smoke at all during normal operating temperatures.
    I found a broken piston ring on my engine, as well as worn, tapered cylinders, causing low compression.
    I would do a compression check on your engine, and perhaps have the injectors tested at a fuel shop.
    Casey
  8. levib
    Aug 30, 2004
    68
    Avondale, Arizona
    As far as compression check goes, can I use a gas motor compression tester or do I need a diesel one? What compression should it have? And is the only way to test the injectors at a shop?
  9. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    The following info has been stolen from David (AgDieseler) and reprinted by me without his expressed permission.
    As far as testing the injectors, you can do that at home. With the engine running, loosen the fuel line at the injector for every cylinder individually. As you loosen the line, fuel should start squirting out prety good at some point. When this happens, you will notice the motor sound slightly different, cause its not getting fuel to one cylinder. If there is fuel squirting out of the line and the engine does not change at all when you disconnect the line, that indicates a bad injector. If there is no fuel squirting out, you have either a clogged fuel filter or a bad lift or injection pump.
    You will need a special diesel conpression tester.
