Excessive Tread roll (after new tires)????
Discussion in 'The Garage' started by gmcjimmy88, Nov 12, 2006.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I just put two new tires on the rear of my Gmc 2500HD ext cab 8 ft bed. I did it all myself so I did the normal jack at the center diff (14 Bolt) and raised both wheels off the ground. After replacing the factory Brigdestone V-Steel's with Falken landair H/T's (both 245/75R16's) I noticed a signifigant increase in what seems to be body roll. I originally thought it was sidewall flex but after following my own truck (that was wierd) I see that the tire barely flexes at all but, the body seems to roll alot. After looking at the new original (spare) Bridgestone I see that the tread seems to be deeper and softer on the Falkens. I then tried to move the lugs on the factory spare and compared it to the new Falkens. The Falkens moved much more with alot less force. Has anyone experienced a similar problem and if so did it correct iotself with miles put on the tires. Was told by one that after a few hundred miles the treads will harden or wear and this will not be a problem. I plan on contacting Falken Mon. A.M. but thought I would post here for any inputs. But after putting 100+ miles on the tires I can say other than the tread roll they have a great ride. I will tow with them in the next few days (after making sure I do not have a defective tire) and will be able to comment on their ability/behavior in that situation. Thanks for any inputs/comments.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    new tires on the rig at work did this, of course they threw tires on with 32/32 of tread though, nice tall rubber, felt like the ass end was swinging side to side on me,,,weird.
    Make sure the tire pressures are up where they are supposed to be, but for the most part, you have more rubber on the tire, it's gonna flex more till it's wore down some.
  3. gmcjimmy88
    Feb 10, 2005
    559
    Pressure is correct at 80 psi. I thought about lowering it a little but not sure if that would help or hurt it more. Thanks for the input though. Mainly wanted to know if I was crazy or if some other people had this similar problem.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    80 psi:eek1: ive never seen a tire run that high of a pressure! always like 30-40
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    I recently put brand new 315/70/17 BFG a/t's on the back of the Burb, didn't notice any unusual swaying on that, but then again, it already does this pretty bad anyways.
    and yeah, 80 does seem alittle high, maybe a light truck tire, multi-ply? heck my BFG's request 50 something,,,
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    fyi the number on the sidewall isnt what the tire should be run at, thats just the maximum load the tire can handle, and the pressure needed to support that load...
  7. gmcjimmy88
    Feb 10, 2005
    559
    They are on a 2500HD. They are also "E" rated tires. The 80 psi is on the sidewall of my new and old tires and my door jambs stickers calls for 80 psi in the rear and 55 in the front. The recommended tire pressure is what I usually go with but the tire only has the 80 psi on it.
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    not sure if you are replying to me, or him, or both, but yes, I understand this, and still only run about 35-40 psi in mine, just so they are not so rough going down the road :D :p:
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    yeah, its whatever the door jamb calls for...i use that as a base and adjust from there. 80 just seems real high...idk if thats whats called for then i guess its good:crazy:
  10. gmcjimmy88
    Feb 10, 2005
    559
    4Xcrazy: What does your tires recommend on the sidewall? I think by lowering the pressure that would give me more sidewall flex, therefore a better ride. I plan on dropping to about 60 psi and check for any differences. Waiting to contact Falken to get there recommended psi.
    Thanks for all the inputs and advice this is what I was hoping for by posting up here. To get more opinoins than just my own.
  11. 4xcrazy
    Oct 31, 2003
    9,471
    5
    mine say 50 psi, but as mentioned, i rarely run them at that pressure, especially here in Arizona, with the extreme heat in the summer, and the road surfaces being extremely higher, i really don't need to be adding more pressure in them at highway speeds, which i do alot of.
  12. gmcjimmy88
    Feb 10, 2005
    559
    That makes since about the heat and road temps. I will update everyone on what Falken says after I call them Tom. I sent them an email but not sure when they will reply to that. Thanks again for inputs.
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    road temp sholdnt affect too much, for every 10* of change theres 1psi differance
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you've never run a heavy duty tire then.
  15. 4xcrazy
    Oct 31, 2003
    9,471
    5
    and what is the standard temp from which this measurement is started from??
    i can't really say there is positive proof, except for all the tire tread laying around the freeways during the summer months, i understand this is mostly due to improper inflation practices, but it would seem the older the tire, the more prone it would be to failure during high speed, high heat situations...
    i dunno, the heat affects everything here in Phoenix during the summer, is can't be good for the tires as well.
  16. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    Lower tire pressures generate more heat in a tire. Just because its hot you shouldn't run a tire at lower pressure. When you run a tire that calls for 80lbs at 30-40lbs you are wasting fuel because it takes more force to turn the tire.
  17. 4xcrazy
    Oct 31, 2003
    9,471
    5
    all i was getting at is, high speed driving generates heat in a tire as well, and when the ambient temps are runnin close to 120, with 150-180 degree temps on the road surface, things get alittle warm, the air pressure will raise in the tire during these runs, putting them closer to the "normal" running pressures.
  18. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I ran 35 or so #s in my 2500HD, been like that since I got the truck. Went to CO twice, CO to TX, NYS to CO towing a car, DC to NYS towing my old 90 RCSB, 2 BBCs, a welder, D60 front, and some other misc stuff and never had a prob. 80 seems high....
  19. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    i run 55 front and 80 rear on my 2500 3/4 ton suburban, it's what the door jamb calls for and the ride is fine. Load range E tires call for 80psi, i've seen some that call for 90-100 on them. Just not big tires like 40s or something, different load ratings and different requirements.
  20. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    I've always found my E rated tires ride really stiff when you've got em aired up to 80 PSI, which is the max pressure listed on all my tires.
    I typically run mine at 40 PSI, they wear well, and ride nice at that pressure.
