Exhaust break
Discussion in '1982-Present GM Diesel' started by schlechto, Jul 2, 2002.
  1. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    I am in process of replacing the head gaskets on my 1987 GNC Jimmy and I noticed some kind of exhaust brake on the driver's side exhaust manifold. Is this a stock item? Is it neccessary, or can I remove it without getting into trouble?
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I believe what your refering to has something to do with the emissions.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    That is a back pressure flap, with is closed at an cold engine. Thus it warms up faster. If this flap wedges, you have a massive power loss.
  4. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    It is called an epr (exhaust pressure regulator).
    At idle your egr valve is open and your epr is partially closed to increase back-pressure for the egr.
    I have removed mine as well as capping my egr port seems to run alot better. The j code engines run with neither.
  5. schlechto
    Aug 4, 2001
    56
    Carnation, WA
    Thanks for the info guys /forums/images/icons/grin.gif I have decided to do away with all of the EGR crap so I guess that it will go into the trash bin as well.
