exhaust comes in my back window....cough cough
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eripley, Oct 7, 2003.
  1. eripley
    eripley 1/2 ton status
    Oct 1, 2003
    145
    knoxville,tennessee
    When my back glass is rolled down (I like the airflow) I get choked out by exhaust. My pipes come straight out the back and have straight pencil tips. I was told that tips that point down might help the problem. However , assuming this will fix or help the problem I cant find stainless tips that turn down. Where is a good place to get tips? Searching on ebay yields the bling bling huge motorcycle sounding honda civic tips. I dont want chrome since it rusts when scratched. Also in my opinion exhaust is to be heard not seen /forums/images/graemlins/wink.gif
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Theres a sorta "low pressure" area behind the truck and the fumes will be pulled thru the back windows.
    In the old days, they use to put these little "airfoils" on the back roof which directed airflow down, over the back window and kept the exhaust out. I have side exiting pipes in the rear (factory) and it does the same. Pep-Boys or Autozone sells turndowns, both plain and chromed. Should also be able to get them at a local muffler shop. Might try it, dont think its going to help too much /forums/images/graemlins/tongue.gif
  3. dyeager535
    26,979
    I think what you'll hear is that the only way to "cure" this problem is to have the exhaust exit out the side of the vehicle, in approx. the stock location. (behind the tire)
    Stock tips were cut in an odd shape. Cut the end of the pipe off flat (call it a 90* angle) then a little less than halfway down, cut back at a 45* angle. I'm guessing this was done to direct the exhaust gas down, as it would lend unnecessary expense if it wasn't some sort of "safety" feature.
    Also, a stock rear spoiler (Suburban ones are the same piece and more common) will cut down on exhaust fumes, but will not eliminate them, even from side exit exhaust. Having the front windows down helps, but in slow moving traffic or acceleration, you will still smell it with ALL the things I've mentioned.
  4. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    it's called VACUUM /forums/images/graemlins/thumb.gif
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Depending on conditions I get fumes even with the factory side exit on behind the left rear tire. Its just the way it is. Low pressure and vaccum doin what its supposed to.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll trade you my truck for your K5. 6.5 or 8 feet of bed between you and those nasty fumes solves it all!
