exhaust cut off ???
Discussion in 'The Garage' started by 80Jimmy, May 1, 2003.
  1. 80Jimmy
    80Jimmy Registered Member
    64
    Idaho
    I have 12" glass packs. The cops said that I have to have a muffler and a catalytic converter since my blazer is newer than 79. I was curious about the exhaust cut. I saw it on tv i think. It is a valve that when opened your exhaust goes through your catalytic converter and muffler. When you close the valve the exhaust turns off to the side before the converter and out the side and it is basically straight piped. Anybody know of any write ups on this or have any ideas for me. I wanted to get ride of my glass packs and try this setup.
  2. alesko
    alesko Registered Member
    Apr 27, 2003
    47
    sw pennsylvania
    They are made by a company called Dougs. Thats all I know.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    They're called exhaust cutouts. Those fancy electric ones from Dougs that were seen on Trucks TV cost $450 for a pair. /forums/images/graemlins/eek.gif JC Whitney sells some cable operated ones that are WAY cheaper.
  4. alesko
    Apr 27, 2003
    47
    sw pennsylvania
    If you would like to make a cheap set of homemade ones,try this. Go to the hardware store and buy a piece of 3 inch black pipe about 6 inches long, threaded on both sides. Also buy 2 threaded caps, 1 for each end of the pipe. Cut the pipe at a 45 degree angle inthe middle. These will be your turnouts. Notch them to fit your pipe, cut pipe, weld in place, and use plendy of antiseize on the threads.
    This is a cheap way out, but you may have to lay on the ground to remove the caps.
    I ran these on a pulling truck for a couple of years and they worked great.
