Exhaust decissions
Discussion in 'The Garage' started by big_truxx, Apr 27, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    I want to redo my dd's exhaust and I have some questions.
    What is a good size pipe to run for a 350? Is 3" too big? Is 2.5" better?
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I think 2.5 is plenty if you're running duals. You've gotta keep in mind that volume increases exponentially with diameter increases.
    2.25" = 3.97"sq
    2.5" = 4.9"sq
    3" = 7.07 "sq
    You can see how drastic a difference there is. As 2.5 would be sufficient, 3 would be approaching excessive IMO.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Single 3" IMO.
    John
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    dual 2.5
    single 3"
    I have a single 3".... alot louder than a dual system seeing as i live in cali where 2 cats are required for dual exhaust
  5. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    On near stock engines a 2.0" dual setup is fine, when you start getting up around 400hp then you wanna open em up to 2.5".
    if you wanna bump up the bottom end w/o hurting the top then install a crossover pipe between the collectors and mufflers, mine is directly behind the transfer case.
    a crossover pipe will also smooth out the exhaust pulses, even with #40 2.5' flowmasters and duals exiting behind each rear tire my exhaust note is off the chain and very loud when the power starts building (you outta hear those pipes ring) , probably need some resonators.
  6. 76blazerguy
    76blazerguy 1/2 ton status
    Nov 15, 2004
    125
    wichita, Kansas
    sorry to hijack but i need some help to. i currently have the stock exhaust and exhaust manifold apart from a flowmaster delta flow muffler. Im going to go ahead and get a new system in a week or so. This is my plan as of now. Flowtech afterburner headers, magnaflow x pipe 2.25's. 2 flowmaster super 40's both 2.25s and both exiting just behind the rear wheels. and new pipes as mine are rusting away. I know the flowtechs arent the greatest but i can get a set cheap if im quick about it. if anyone wants to know what engine mods its a 350 with a crosswind manifold, K&N filter, K&N xstream lid, and a edlebrock 650 thunder series carb. what do you all think? anything you would change.
  7. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    sounds fine...
    you'll see why the afterburners are so cheap when you get your hands on em... they'll make power just fine but the quality of the welds, inside and out along with a coating that comes off when you breath on it makes them hard to look at after a while.
  8. 76blazerguy
    Nov 15, 2004
    125
    wichita, Kansas
    i know this is a really stupid question but are there any other "cheaper" headers you suggest? im really scraping for money for my truck right now but i guess like all you im pretty addicted to it. also im not really interested on the visual of my headers i just dont want leaks or problems along the way.
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I don't want to keep takin this thread OT but afterburners are good headers if your looking for power... underhood temps and fitting them can be a problem tho... my coating came off after 2 starts of a brand new 355 and i also had to grind the frame about 1/4 inch to get them to fit.... i would have bent them but the y pipe wouldn't have fit. I Like the sound tho.... sounds damn good with a 3 inch single and a generic flowmaster.
    dyno max makes a good header for about 250 but they're ceramic coated so 250 is a good deal...
    As far as leaks go, red rtv on the header or gaskets is supposed to seal them up tight.
  10. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    ok dual 2.5" is settled then :D :waytogo: already ruinning 2.25" duals w/ stupid glasspacks and no turn downs :haha: I'm sure the new system I build from parts from summit will be much better. I will not need an xover it's just my DD 82 crew dually ;) I always thought 2.5" max on SBC and use 3" on BBC :waytogo: Was really trying to confirm my opin by other people's :D
  11. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I have a set of summit headers :D summit=good :waytogo: also not expensive
  12. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    On my old '79 I ran dual 2.5 w/ an H-pipe and a pair of Dynomax Thrush mufflers - it sounded great! The H-pipe made all the difference in the world with sound.
    Though I think dual 2.5" was too big for a stock 350 w/ and edelbrock top end.. I doubt I was even pushing 275hp out of it
  13. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    It all depends on the horsepower bro....2.5" max for most street driven SBC's
  14. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Don't get the flowtechs man.......Hedman or Hooker competition hedders,
    those are my 2 choices
    do you see anybody in the know running flowtechs...?
    me either.!
  15. 76blazerguy
    Nov 15, 2004
    125
    wichita, Kansas
    ok i guess i should have known better to buy the cheap option, but............. what are the summit headers like part no. SUM-G9006-9 . i know they are still cheap but are ceramic coated and summit have always been pretty reliable in my past expierience with them.
  16. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    that'll work fine bro...they are full length hedders and will serve you well
  17. stus84
    stus84 1/2 ton status
    Mar 21, 2005
    109
    MN
    Exhaust
    "Dynomax Thrush mufflers" I have heard good things about these... From the 350 I run hookers to glasspacks out the sides in front of the rear tires.. I was thinking of upgrading myself... the glasspacks were cheap but it is time for an upgrade... Let us know what you decide to run..
  18. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I was running Assmaster 40 series w/out an H-pipe and it sounded HORRIBLE.
    I was very happy when I went to the Thrush's & H-Pipe over the 40's, and sold the used Assmasters for more than I paid for the thrushs :)
  19. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    not sure who makes the headers on my 75 but that has full length headers and flowmasters I believe they are 40's and it sounds good w/o xover :dunno: also has a mild cam in the 350 :D
  20. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    I have the same set, uncoated... I wish I had gotten them coated, cuz they are fricken HOT... otherwise, good all around header...
