Exhaust Exit and Fumes in the Cab...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Nov 9, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I know that if the exhaust dumps straight out the back, I will more than likely get a big whiff of exhaust fumes when the rear window is down. My question is how much does a rear wing help to deter the fumes when it exits out the back. My current setup is stock(pipes exiting at 90 degrees behind driver side tire) and I can only smell the fumes(with rear window down) sometimes when at idle for extended periods of time. Thanks for your advice[​IMG]
    [​IMG]FUN WITH 31's![​IMG]
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    There was a post about this a while ago and if I remember right, the wing helps a lot. I have my pipes exit pointing towardthe corner and I can smell it a little when driving, but its not too bad.
    90K5
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    On that note, has anybody installed a rear wind deflector other than the stock GM one? There are a few different manufacturers out there that make aftermarket ones- maybe someone has a pic of one on their Blazer?
