exhaust exits
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Oct 24, 2001.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    to help cut down on the fumes should I have the tips of the exhaust go out to the side (behind the rear tires) or point to the ground above the rear axles any thought tips would be helpfull thanks.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My dual exhaust exit behind the rear tires. I drive with the rear window down a least a couple of inches 95% of the time. I have never had a problem with fumes yet.
    My Chevy isn't broken, its just out of gas.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Generally, your best bet is out the sides. Out the back (or pointed down, same thing I think) the exhaust gets pulled into the low pressure area behind your mobile brick (i.e. K5) and will often come inside with you (unless you have a better seal back there than 90% of them).
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Really? Do you have the front windows cracked at the same time? That would create a draft through and help keep it from coming in. My '75 came inside at times even with the window completely up (bad seals and not enough interest in replacing them) until the pipes got mashed. After cutting them off back near the axle I had them rerouted out the side, no more exhaust for me.
    Russ
  5. dyeager535
    26,980
    To cut down on internal fumes, definitely out the side. Truck doesn't have enough ventilation undernath when sitting to properly evacuate the fumes. Chances for Carbon Monoxide poisoning too great for me.
    Personally, if I can see the pipes, I like them routed and the tips cut just like GM did on these, with that "half 45 degree" angle tip. (and single pipe on either side, makes it easier to route as well)Take a pipe end, then halfway down, cut a 45 into it. Looks great, especially true duals like that.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    During the summer I run with the side windows down (no A/C), but often during the spring and fall I run the side windows up and the rear window down a couple of inches. Also on the highway I run the rear down and sides up. Never had a problem yet.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That's the way I have my exhaust done. With the 45 degree tip. I think it looks good. The only reason I don't like it is it loads up with mud. During elk season when I'm running lots of mud I have to get out every 2 miles or so and kick the mud off my tips so my engine will run right. Had that problem with the stock exhaust too.
  8. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    thank you to the side it is..2 of my friends just had it go to the axles and I thought it was kind of asking for it but to each his own right.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh, sorry Hoss, I misread. I thought you said you had it out the back with no problem. We were saying the same thing. Ok, first thing on my "to do" list, learn to READ! LOL! [​IMG]
    Russ
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I like mine out the side anyway, it echos off things, like the drive thru and under bridges.
    Tim
