Exhaust Flamethrower Kit
Discussion in 'The Garage' started by k5freak44, Oct 27, 2004.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Do these kits work real well with k5s? I have headers, true dules, and 2 cats that dont work very well. I wana shoot out some big flames so i can show off around a bunch of ppl and to scare away all the little ricers.
    Any one tried a kit that dosent use a additional gas? Thats what im looking for.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have seen flamethrowers, but never seen anyone that bought a kit for it... mostly just homemade stuff...
    Do those meet USFS Spark Arrestor Standards??? /forums/images/graemlins/rotfl.gif
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    how big of a flame they put off?
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have seen people build them w/ a manual choke and a spark plug in the exhaust pipe w/ a hotwire... They shoot quite a ways.
    Our old Bronco w/ a 351M and all the smog stuff taken off, but w/ the air pump still hooked up would shoot them about 15' just by jumping on the gas for a few seconds and then letting off...
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    This is the way I have seen them also, with the spark plugs in the tips and coils to spark them.
    How do you operate it? Where does the manual choke come in? When should the spark be on/off? /forums/images/graemlins/ears.gif
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    That's the way to win friends at the local police department and represent off-roading in a positive light /forums/images/graemlins/thumb.gif
  7. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    This sounds like a question I would ask.
    Well, if you can find a legal kit in the USA good for you.
    If you can find a sneaky kit from outside the country, good luck to you.
    Me? I would just have someone dump a bunch of gas out the back and light it on fire... /forums/images/graemlins/weld.gif
  8. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    i saw a kit on a car show that would drop a cylinder from firing and spark the one in the tailpipe. it only works if you have no cats and a straight through exhaust. i want to say that there are some propane numbers out there that you could rig up. or just run zoomies out the hood. then you can see the flames too. /forums/images/graemlins/peace.gif /forums/images/graemlins/weld.gif
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Bingo..........................
    Not to mention, "show off" and "scare the ricers." Questions like these are just plain stupid and should be left at the Type R shop.
  10. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    My friend has a flamthrower he built in his cutlass.He simply took the breaker plate from an old points style distributor and bolted it to a power window motor,using its drive gear as the "cam" for the points--then hooked an HEI coil to it for the spark(he used an externally mounted one,like some six cylinder's used)--and he welded some spark plug "non foulers"into his tailpipes to hold the sparkplugs.He hid the coil and homemade distributor in his trunk,and spliced 2 plug wires together to fire the plugs.
    He can get flames about 10 feet long fairly easy--rev it up a few times in quick succession,and hit the switch while the rpm's are coming down,and WHOOF!--it looks like a jet engine during takeoff!--and yes--the cops hate it with a passion!--he made the mistake of firing it off when a cruiser was behing him one night,and he decided to make that "tailgater"back off some--then the blue light came on,and he was /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif--they gave him a "fix it" ticket,and warned him if they caught him using it on the street again,his licence plates would be removed and the car towed away.He only uses them at car shows mostly now!. /forums/images/graemlins/crazy.gif
    I'd love to run those "zoomies"right thru the hood,like the truck pullers use--that would be cool seeing flames in front of you going down the road--might be handy to de-frost the windsheild in the winter! /forums/images/graemlins/grin.gif
  11. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    ive found some kits that claim to work online. im just afraid to waste 60 bux on something that will shoot out lil puny flames.
  12. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,001
    597
    Pueblo, CO
    Give me the $60 and I'll buy a bottle of everclear and a lighter for you. get a mouthful of everclear and spit it out over the lighter. Same effect, just as dumb and just as dangerous to you as a flame thrower kit is to your engine and catalytic converter.
    Honestly you can do whatever you want, but if you are tyring to intimidate Ricers you are only asking for a fight, plus invite the law to come check you out too.
    There are better things to do with your time. Besides what it takes to do it right is darn near impossible to do with fuel injection. Overfueling and cutting the ignition to load the exhaust with raw fuel is going against what all computer controls do. Besides raw fuel in a converter is a good way to kill it.
    In my opinion, flamethrower kits are ok on a '49/'50 leadsled Merc or other Kustom's from the same era and are otherwise pointless on anything else. At least the folks that own/build those rides are mature enough to know when not to use them and when they do it's done responsibly to show off, not intimidate.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Im gonna have to agree with ya on this one /forums/images/graemlins/waytogo.gif
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    im putting a flamethrower kit on the hotrod truck im building. its no 50 merc, but it'll be somewhat kustom.
    what i've learned is:
    1, they dont work w/ cats
    2, you need a carb'd motor
    3,works best with a manual choke carb.
    if i was you i'd just take them off.
  15. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    [/ QUOTE ] $60???? hmmm lets see, that could buy a set of zero rate add-a-leaves from ORD or a pair of offroad lights or a shift kit for your tranny or a lot of other USEFUL stuff....
    lol im just kiddin man its your money do with it what you like.
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    There's a guy on FuelSlut that does/did make various kinds of flamethrower kits. If you decide to head on over there tell them wrath sent you.
  17. dyeager535
    26,979
    I'm not advocating the flamethrower idea (even though they aren't my cup of tea) I don't see why you need a carb.
    Valves are still opening and closing, piston is still sucking and pushing, if you drop a cylinder on a true dual setup, with the O2 sensor being on the OPPOSITE bank, then the ECM won't know what's happening on the other side of the motor.
  18. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    hey those cars in 2fast 2 furious had flaming exhaust, it was pimp tite yo /forums/images/graemlins/rolleyes.gif
    i can just see the new 3fast 3 furious, the ricer kids and their redneck cousin in his flame spewing K5. /forums/images/graemlins/rotfl.gif
  19. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    so your saying to cut spark to one cylinder and thats supposed to get enough raw fuel to the flamethrower?
    maybe you dont have to have a carb, but it sure is alot easier to achieve a good result. all you have to do is cut spark at high rpm, simultaniously stomping on the gas and the motor will suck a bunch of raw fuel thru. how do you achieve that with fuel inj.?
  20. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    my 42 pontiac would shoot 6' flames with ease
