exhaust fumes gettin to me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGBIRD, Apr 17, 2002.
  1. BIGBIRD
    BIGBIRD Registered Member
    Apr 17, 2002
    21
    North Carolina
    have a 6" lift on a '75 with flowmaster exhaust that exits dead even with rear bumper. Open any window and you get gassed. Engine not running clean (running righ and timing has no effect), but at 60 mph you ought to be able to get away from it. Is the 6" lift the problem. Has anyone else had this problem ?
  2. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    My truck did the same thing after running dual pipes out the back on each side of factory hitch. GM must have had this in mind when they ran the pipes out the side. I'm thinking fumes is going under rear door seal , mine is worse when any windows is down. I might try one of those rear deflector things that is supposed to keep rear window clean, maybe that will change airflow?
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Anyone have any pics of their dual exhaust. I do not want them in the rear beacuse they get smashed. Behind the tire wont work with the shackle flip. I am thinking of going out in front of the rear wheel if I can get them somewhere they aren't going to get smashed. I can almost fit them into the fenderwheels since I have a 3" body lift. Thought I might cut a hole infront of the rear fender and run them out the side of the truck or something different.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The only real fix for this is to get the tailpipes run out the side of the truck. I was warned not to run my dual exhaust out the back because of this very problem. Your truck leaves a nice dead air space back there, and the exhaust sits in it, and flows into the cab.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Hey, I resemble this remark.../forums/images/icons/tongue.gif
  6. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    Good topic, I was just thinking of this today. My truck has the factory style single exhaust coming out behind the drivers rear wheel and I was getting gassed today with the rear window open. If I get my dual exhaust made to exit in front of the rear wheels on each side will this solve that problem? My truck has running boards (my wife and son need them to get in/out) so its gonna get tricky. Maybe I could point them down to clear. I dont know - just rambling.
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    All I can tell you is what works for me. I have a 79 K10 with 8" of lift and 44's. My exaust is headers to 1chamber flowmasters with turndows (about 45deg down and 45deg out) right before my rear end. I have not had any "gassing" problems on the road or on the trail.
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have the same problem. What causes it is driving down the road you create a vacume behind you so the gasses go right back into the window. I had to run mine out the back when I did the flip but after the new rear springs go on with the 9012's I will have it moved to come out the side.
  9. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I have dual exhaust exiting out both sides right before the rear bumper (this way a shakle flip sill still work if I do so) Even thought the pipes stick out the side I still get exhaust smell in the back window. I think it's better than straight out the back (shop I had it done at says they stay away from that on broncos and blazers). I think you should expect some exhaust to come in no matter where the pipes dump.
  10. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    I think I am just going to go full out redneck (since I am one)
    Does anyone know where I can get some upwards headers that will just go through the top of the hood and I can call it good.
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    on my truck (yeh its not a blazer) i ran mine out on both sides, in front of the rear wheel if u look at the pics of my truck, (lift pic) you can see my stainless tips running, will take some better pics of exhaust later, dual cats, dual 50 series flowmasters, and 2.5" pipe in front of the rear wheels sounds pretty good, and i dont have any probs with fumes.
  12. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    This is a common problem on blazers. You can do 2 things. Either run the exhaust out in front of the rear tires, (which ia bit louder than some like it) or you can dump them right at the back axel angled towards the tires. That way when the exhaust exits it gets dissipated by the air turbulence caused by the rear tires. Anywhere else, and it'll find a way into the cab.
  13. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> I swear most of my gas smell was coming from the rotted rear floor !!!
  14. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    With the top on and the exhuast exiting under the rear bumper I would suck fumes bad. with the top off I don't notice it at all. I was thinking of running my exhuast out behind the front tire, mufflers between the door/floor and frame but protected by sliders and exit the exhaust before the rear tire out the side. It frees up a ton of room under the truck which is great if you want to get tricky with the suspension.
  15. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Now, that's almost as bad as mine LMAO!! /forums/images/icons/smile.gif
  16. joker89blazer
    Nov 21, 2001
    130
    Has anyone tried those air deflector things that mounts on roof and helps to keep rear window clean by making air flow blow down window rather than letting a vacuum pocket suck dust on back window? Would this stop the problem of fumes getting sucked behind truck also?
  17. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Supposedly yes. My last blazer had one on it and it wasn't as bad, but I could still get gassed going down the road. It was a '79 with single 3" exhaust that came out right in back of the rear tire. I would like to find an aftermarket one to fit my '74 if they make such a beast.
  18. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had an air deflector on the back of mine and all it did was pile dust onto the back of the vehicle while driving down dirt roads. I took it off for better access to my roof rack and found that the back window stayed clear.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    K20,
    No matter what you do, on a truck, you'll never breathe fumes. The bed is breathing fumes, but nobody's back there to complain!!
  20. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Supposedly tips at 45* angles will fix this I have them and still get the gas in the back at low speeds. I can only open the rear window once above 50mph anything lower and the turbulence drags the smell into the cab. I also wonder if the spoiler will help. If you ever look in a flowmaster catalog it shows the windflow behind a suv and strongly recomends against pipes straight out the back on any truck or SUV. The air flow loops right over the tailgate and into the bed. Also if you can leave exhaust marks on trailers you might pull.
