Exhaust Fumes
Discussion in 'The Garage' started by Indyblazer, Jan 14, 2006.
  1. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    I get lots of exhaust fumes inside my 84 K5 when I am parked with the windows rolled up. I notice the fumes as soon as I park the truck with the engine is idling. I don't notice any exhaust odor when the truck is moving.
    No rust holes anywhere... Southern Truck. 8 month old exhaust system from the engine back. Plus, I had the mechanic re-check for leaks this week.
    Could the fumes be coming in around the tailgate? The stock tailgate gasket looks OK. The new exhaust turns out to the sides like the original stock system.
    Any other places to check that you could recommend?
  2. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    hummm,
    this is probably irrelivant but does your truck have any blow-bye, if so than it could be getting sucked in through the vent for the heaterbox, OR your rear window and, or tailgate gasket is letting it in, im also stumped but thats a start....
    LUKE
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Have you got an intact rubber weatherstrip across the bottom of the tailgate and up both sides of the tailgate?
  4. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    Ive had a slight collector leak and the fumes would rise up through the T-case shifter hole in the tranny hump and come into the cab that way.
  5. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Me too. I would definately check that out.
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Did or do you have a spare tire mount on the inside of your k-5? Are all the bolts in? II had to reinstall the bolts in mine for the same reson..
