Exhaust gas question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jul 20, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Why would the driver side bank (drivers side exhaust) be burning richer than the passenger side? or vice versa. It has true duals. One side has more exhaust gas exiting than the other the same one smells richer than the other. Any Ideas?
    TIA
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, that's a silly idea. I can't imagine it being possible unless someone had stagger jetted a carb incorrectly.
    You're sniffing too much exhaust. :)
    Tim
  3. Redfrog
    May 4, 2001
    753
    IL
    Hey guess what, It is possible because it is happening right now in my 79' :) as far as the jets in the carb goes I did not think of that. After all it is a junk holley thanks for the idea
  4. Redfrog
    May 4, 2001
    753
    IL
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    With a Holley it is possible to stagger the jets. That might be what you have here. (I kinda think it's unlikely) If you have a dual plenum manifold, both sides of the engine are fed with both sides of he carb.
    Check the plugs, pull the plugs and if you do have a problem, the plug should "tell" you. If one of the plugs have a different color then the rest- something is wrong. Check the gaps, plug wires, and compresion.
