Exhaust Ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BaylorK5, Aug 3, 2001.
  1. BaylorK5
    BaylorK5 Registered Member
    Aug 2, 2001
    8
    Beaumont/Waco, Tx
    My catalytic converter, pipes behind the cat, and muffler have all seen better days, It doesn't take a genius to hear the leaks in the exhaust at idle. What do you guys recommend? Being a college student I really don't want to break the bank here but I want quality products with good tone. Those qualities usually lead to breaking the bank however. Thank you in advance.
  2. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    You have just described open exhaust!!!!!!
    But I wouldn't recomend it!!!!!!!!!!!!!!!!!
    Keep it simple!
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Grab a catco catalytic converter anda flow master after cat. system. Total shouldnt be over $275 parts, labor is the only variable. This will give you a single-rear-drivers-side-exhaust exit.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check into the Flowmaster Force 2 cat back system. I think http://www.summitracing.com/ sells them for around $250.
    For the converter I would go with a Catco cat They are about the same price but flow better than stock converter.
  5. BaylorK5
    Aug 2, 2001
    8
    Beaumont/Waco, Tx
    I really appreciate it guys, I'm gonna check into that idea.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i took mine to a exhaust shop and had true duels put on from the manifolds all the way back to right behind each tire with flowmasters put on for $350 i dont have cats but you said you only need from the cat back just my .02
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Stop in at your local muffler shop and get there price to do it.....also tell them your low on funds and see if they will just bend you new ones that you can install......
    C'moe
    <font color=black>the blazer is "Back in Black"
  8. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    if the cat is good just go to the shop and run straight pipe probaly cost around 70 bucks.
    i did this with true duels and it only cost me 100 for it, so one pipe should be cheaper.
  9. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Yeah.. Flowmaster's..
    I have 2 40-series dual chamber's on mine...
    I love it.. not to loud.. not to quiet..
    As for Cat's.. mine were removed when i bought the truck.. so I don't intend on putting one back in.. until it becomes mandatory..
    And.. hello Fellow Texan..
    My girlfriend grew up in Waco./ Hewitt area..
    You interested in a off-road run?
    Round Rock, Texas I haven't failed, I've found 10,000 ways that don't work. <a target="_blank" href=http://www.rocko.rockcrawler.com>www.rocko.rockcrawler.com</a>
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Hey Charlie, do they give you crap about not having cats when you get your inspection sticker?? I have to get mine this month and I ain't running cats.....
    <a target="_blank" href=http://www.k5.rockcrawler.com>Click here to see my K5</a>
    *<font color=red>under construction</font color=red>*
  11. Hey mudhog! Did your truck come from the factory with true duals? If not what state are you in where you can convert to true duals legally? OR is it not?
    Damn I need to learn how to use my welder!![​IMG]
    (90 Jimmy 350 TBI, 14 FF/10 bolt, 4.56, tires ??
    (ftn96)
  12. BaylorK5
    Aug 2, 2001
    8
    Beaumont/Waco, Tx
    Rocko......
    I'd definitely be interested in a run sometime, I'd have to know a while in advance though because the blazer is going to stay in Beaumont with my dad and I'm gonna drive his 95 camry. I'd love to take the blazer, but it would be much cheaper for my dad to drive it, and easier to work on. I'm sure I'll take the blazer up to Waco occasionally.
