Exhaust is now installed, pics of course
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Yukon Jack, May 24, 2005.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Drove the K20 to American Muffler and had exhaust installed. The system is 3" pipe from the headers to the x-pipe, then 2 1/2" to Dynomax UltraFlo's and continues as 2 1/2" pipe dumping at the rear of the flatbed angled down slightly. The truck is running pretty rough, back firing or missing - now that I can actually hear the motor it sounds like a timing issue and a rocker or two need to be adjusted.
    Here are some pics of the system. This is the X-pipe that I had built by someone I found on E-bay.
    Rather than use the collector piece that came with the headers, American Muffler made their own piece
    The passenger side collector was fairly close to the transfer case. Here is a pic of the pipe coming over the transfer case
    Here is the X-pipe installed directly behind the transfer case
    And here is an example of the welds at the X-pipe
    Here are the Dynomax mufflers
    Pretty straight shot to the rear of the truck
    The pipes dumb right before the hitch and are well protected
    As the motor is running rough I have not gotten on the gas to see how the system sounds - will have to wait to see what is wrong with the motor.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    YYYYYYYYYYYYYYYYEEEEEEEEEEEEHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAA :D
    Damn that looks cool. Crazy how long the rear pipes look in a pic. Looks like you too had a good shop doin great work :D :D
    Good luck on the stumble....
    Burt
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    that body lift makes it easy to stick that exhaust up nice and high,eh! :thumb:
  4. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Looks great! I bet it sounds great too...Or atleast it will when the engine is running smooth ;)
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    What is that extra crossmember you have behind the transfercase for? The one with a small skidplate on it.
  6. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    At first I thought that was where the carrier bearing is located. But looking again I think the carrier bearing is about a foot behind it. I will take a look and let you know for sure.
