Exhaust Kits.... what works?
Discussion in 'The Garage' started by Calclips, Jan 26, 2004.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've got a set of hooker competitions headers on my 82 K20, and was wondering if anybody has tried to install one of the exhaust kits that comes with all of the pre-bent pipes, like this dynomax kit from Jegs. The truck has a TH350 with a 205, wich I do not believe is stock for the truck.... does this complicate the issue? Also, what other pre-bent exhaust kits has anybody tried... and what kind of success have you had (any modifications necessary?). I'm looking for a true bolt on exhaust kit... I don't want to have to mess around with modifying all the pipes and whatnot.
  2. Calclips
    Apr 4, 2001
    1,005
    TTT.... anybody?
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I used that kit on my '78. I have a set of Hedman headers and I used dual Dynomax super turbo mufflers. The kit worked well, but if you decide to use a clamp together system I would suggest that you get all of the fittings welded after you have installed it. Exhaust clamps never seem to hold too well. /forums/images/graemlins/waytogo.gif
  4. Calclips
    Apr 4, 2001
    1,005
    The kit itself went together without modification, right? That is all that I am worried about, because if I have to do mods to it I'll just go to an exhaust shop and spend the extra 50 bucks or so to have them bend and weld me a whole system.
  5. dyeager535
    26,976
    Well, like he suggested, if you need to have it welded up anyways, how much is the "kit" really going to end up costing, compared to having a shop do it for you?
  6. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    a friend i grew up with just opened a muffler shop.let me call him and see how much,he does custom work. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  7. blasterD
    May 24, 2003
    410
    Anchorage Alaska
    My kit went together just fine. If it's only $50 more, I would go with a custom system. I couldn't find anybody to do a full system for less than $300. That is why I went with the cheaper kit ($100 + mufflers)
  8. boggerless
    May 26, 2003
    22,728
    96
    he said $240.00 with turbo mufflers all the way back(2 1/2 in), or $200.00 if you want to buy your own muffler's. i don't know what you want but i'm sure if you went 2 1/4 like jeg's and other changes it would be lower. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. Calclips
    Apr 4, 2001
    1,005
    I know a muffler shop in Durand, MI (just over in Shiawassee CO.) that does good work cheap. I didn't really need a full system all of the way back, so I'll probably call up Dave's and have him do it. I believe he did the same job for a friend of mine for like 150 with 2 1/4 pipes that dumped off under the bed. I just happened to see a kit without mufflers (I have two flows I'm gonna put on it already) in Jeg's for our year trucks that was going for like 99 bucks... thought that if it was a good deal I'd just go with that... but oh well.
    Thanks for the help guys
  10. Calclips
    Apr 4, 2001
    1,005
    BTW boggerless... where is your buddy's shop at? I doubt that its gonna be closer to me than Dave's... but I may have to check it out.
  11. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    How loud are the super turbos by dynomax? Are they just as loud or louder then the flowmaster 40 delta?
  12. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I used this Dynomax system on my '87, I had to take the pipe tha goes past the transfer case, an have it bent up a couple inches. Otherwise the pipe on the left side was going to go under the transfer case bracket. Other than that problem, it works great. I used exaust sealer on all of my connections, so I didn't have any leaks.
  13. jwduke
    Aug 25, 2001
    721
    They don't seem much more than stock, really.
