exhaust leak...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Nov 23, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    does an exhaust leak make an tick noise when accelerating, and gets faster the harder you push the pedal to the metal[​IMG]. And its not really that big of a deal, is it? I will get it fixed when i get my headers installed because that's where it is now is right after the stockers, but probably not for a little while.
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Yeah, sounds like an exhaust leak. have fun with the headers.
  3. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    You wanna hear exhaust leaks, wait till you have had headers a while!
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It could also be a lifter........they sound kinda' the same. I agree with gopherkiller about headers and exhaust leaks- I used to run headers on a truck I used to own and it seemed like once a month I was under the hood tightening up the nuts to stop the "ticking"!!!
  5. Grim-Reaper
    7,385
    Atlanta
    You might try getting under the truck and tightening the flange bolts on the down pipe. they may have loosend up. Also you have a heat riser on the passenger side pipe that closes when it's cold to direct the exhaust through the intake. Those things like leaking when they get old or the bolts get loose.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
