Exhaust manifold A.I.R. tubes
Discussion in 'The Garage' started by Muddytazz, Apr 8, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The air tubes on the exhaust manifold that run from the smog pump on a small block, do they come in different configurations or where they ALL routed the same exact way?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I could of swore I seen some different ones on other applications. On the small block trucks I have seen one side has 4 ports into the manifold and the other side has only two, mine is like this. /forums/images/graemlins/k5.gif
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    On mine, there are 4 tubes going into each manifold. If I can find a way to to change the drivers side to a different way I'd leave everything there and just change it. The problem I'm having is the drivers side air tubes inlet(from the smog pump)run right in front of the head, which is in the way of mounting my york bracket /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    There are different configurations, i have seen them where there are only two on each side, they run on all four corners. Mine doesn't have any.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    See my dilemma with mounting the york bracket....the 4 port on the drivers side is off the pic on the far right.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So thats the difference , mine runs up , and the hose goes over intake. I have 4 on that side too. Our manifolds are different. Must be the engine size perhaps. My manifolds are on a 305 and look like car manifolds, yours look like standard small block manifolds with air tubes. The exhaust ports are in the same spot, so you could use 83 305 air tubes on your manifold to bring that pipe up and out of your way. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
    BTW I don't have the pics here at work , sorry
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have one picture of mine here I found, doesn't show the side view, look where my AIR hose attaches over valve cover, this is the air tube you need for clearance of your bracket. This is right next to carb, far away from front of motor.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    mine only has one on each manifold
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Can you get me any pics?
  10. sandawgk5
    Oct 28, 2003
    6,881
    Ya I will try to get some when I get home and I will post them up here.
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  12. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    Mine also has the single port setup and I would gladly trade you for your 4 port tube setup as I just got headers that have 4 ports, so I have them blocked off but need to get set back up before my next emissions test or it will fail visual.
    I would assume you would be interested in the manifolds as well?
    It's off an 88K5 with TBI350. PM me for more info or if you want to try to make a deal.
    Sean
