exhaust manifold and rtv
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suffergauge, Nov 1, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    Who uses rtv on their gaskets and who doesn't? What are your reasons?
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I use Super Gold or Copper Silicone RTV or something like that. This is O2 sensor safe.
    Works great. The only time they leak afterward is when I take the collectors or the exhaust manifolds off. /forums/images/graemlins/smile.gif
    It has worked for the last four years on my 383.
    BTW: This only worked for about 8 months on my 402. /forums/images/graemlins/shocked.gif
  3. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    i do
    i use ultra cooper on mine (2 sbc engine whit header)
    and if u got header use the gasket for the cast iron manifold, they last a lot longer then the gasket for the header .
    if u got regular manifold dont bother just bolt them on and GO
    felpro# ms 9275b
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I just use a gasket, no RTV.
    I have heard of this trick in case it leaks:
    Go to the parts store and buy TWO sets of exhaust manifold gaskets. The Mr. Gasket (cheap) brand is OK.
    Get a cookie sheet or something that you can fill with water and let them soak in it overnight.
    Then, use two each and install them. The water will have made them more pliable and when you torque the manifolds or headers down, it will seal better. I assume you'd let the gaskets air dry before you start the engine.
    DISCLAIMER: I hear that in a Hot Rod magazine or somewhere but have not actually tried it. I have saved it in my brain for the day that I have a leak problem at the head, but mine do not leak so I have not tried it.
    -- Mike
  5. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i'm not a big fan of silly-cone if it was ment to have a gasket replace it with a gasket JMO!!!!! /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  6. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    I never have, but the exhaust shop that did my exhaust used the red for the collector gaskets. If ever I need to replace them or the exhaust manifold gaskets, I'm going with the copper gaskets. I have them on my Nova, and they are great!
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Usually you use RTV just to hold the gaskets in place while you are positioning and tightening down the manifold so they dont shift. I dont use any on mine, just anti-seize on the bolt threads.
    Jeremiah
