Exhaust manifold gasket
Discussion in '1982-Present GM Diesel' started by cegusman, Nov 9, 2004.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I pulled one of my exhaust manifolds off to change a freeze plug, the was no gasket there. I never had any ehaust leaks. Do I need to get a set uf exhaust manifold gaskets. I have been told I could just to rub greese around the ports and bolt it back together, will that work? /forums/images/graemlins/dunno.gif
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The 6.2L didn't come with any exhaust manifold gaskets from the factory, and as long as your manifold mating surface looks decent, you don't any gaskets now. Just clean the mating surfaces really well with a wire brush, and bolt it back on. Don't use any grease.
    I've done it both ways: with and without gaskets, and I've never had any leaks either way. When I put my turbo on, I didn't use any gaskets at all, none between the manifold and block, and none between the turbo and manifold. I did use some high-temp silicone on the turbo mating surface, though, but nothing on the manifold to block surface.
    Casey
