Exhaust Manifold Installation
Discussion in 'The Garage' started by B_to_C, Jul 27, 2005.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Ok, I have emmisions coming up so I actually HAVE to get this done...
    Just a simple question: Do you use high temp RTV along with the metal gaskets? And if you don't use RTV how do you keep the gaskets in place while you're putting the maifold back on?
    Thanks.
  2. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    I used RTV when I installed mine. I used the RTV high temp ultra copper. Its more oil resistant.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i use none, metal to metal,
    good luck
  4. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    X2.... I don't use any gaskets at all, just tighten the manifold right to the head.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Most of those manifold gaskets don't have traditional bolt hole in them. They have hook shaped bolt holes that are open on the bottom so you can get all the bolts started without gaskets, then slide the individual gaskets between the head and manifold...then tighten the bolts.
    Rene
  6. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    I never use them either!.....
    I just put them on without any,just like GM did factory!,,every time I used a gasket,even with RTV red hi-temp silicone,they would eventually blow out and leak..
    I have the manifold shaved flat on a surface grinder if its warped at all at a machine shop(they charge about 15 bucks to do it locally)..I havent had any troubles putting them on "metal to metal"...I think headers need gaskets,but not stock cast iron manifolds..and on headers I'd use the solid copper or aluminum ones(I prefer copper--expensive,but they last,and can be re-used)... :crazy:
