Exhaust manifold spreader?????
Discussion in 'The Garage' started by SUBFAN, Jul 20, 2004.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Am I crazy, or have I seen these before?
    The problem is getting the warped a$$ mannies put back on after the head swap. I need to gain about 1/8th of an inch.
    Ideas /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Yes, there is such a tool as exhaust manifold spreaders, but they are best used when placed onto the manifolds, before the manifolds are removed...and not after. For a V8 engine you will need four of them.
  3. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Thanks....Any ideas on what to do now, without having used them first?
  4. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    buy a set and spread em . u can use them after they r off . mac tools sells them or any parts store can get them
    Kevin
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    snap on tool, and Matco tools carry the same tool, I looked at mine and it does not have a part #, think it is generic, I bought it from snapon. /forums/images/graemlins/waytogo.gif
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif Something to search for tonight.... /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Anyplace local????
  8. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    You could put the manifolds in a wood stove or gas grill and get them nice and hot--you'll need good gloves to handle them after,but the bolts will go right in!.I did this during a motor swap and was pressed for time,seemed everthing that could go wrong did--I was putting new studs in the manifolds,had to remove them to drill out the old broken studs,then they wouldnt bolt back up--I got very angry and put them in the wood stove I had going for heat,figuring the heat would expand them--it worked! /forums/images/graemlins/grin.gif I guess nothing beats the right tools,but necessity is the mother of invention,as they say-- /forums/images/graemlins/thinking.gif
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    any carquest or napa should have them.
  10. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif They are always closed when I need them most....
    The long pry bar and a helper did the trick....
    Cracked the windshield while sitting by it pushing on said bar /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/screwy.gif
