exhaust manifold stud ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 14, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'm in the process of installing my vette manifolds on my 350.
    The studs in the HELP section don't fit - the size on the box (3/8-16) is not what the studs actually are.
    SO I found some in the hardware store and they installed like butter (new manifold and new stud.)
    So the question is....
    ARe you supposed to tighten the studs down? Or just install them snug? They installed all the way and look like they should, but am I now supposed to tighten it some more (stretch the threads a little)?
    If I seem a little anal about this, it is with good reason. I'd never had an exhaust on my 76 or my 73 that didn't leak AND get loose at the axhaust manifold collector. Once I have these installed, I'll take them to a muffler shop that will warrantee that there will be no leaks and be a happy camper.
    -- Mike
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Put two nuts on it and tighten the outside nut to install them. You want them tight enough to not come out if you decided to remove the manifold. Rust and heat pretty much make sure it never works that way though.
  3. dyeager535
    26,977
    Using either double, or one large *brass* nut, instead of steel will make breaking studs (and thus needing to remove them) history. : )
