exhaust manifold
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Mar 13, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    i just finished rebuilding my chevy 400 sb for my blazer, just one problem, the exhaust manifold from the old cylinder heads wont' fit the new ones i got? Is this regular? and if i buy new headers will they fit the new cylinder heads?
    lost as usuall
    phill
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    some later model exaust manifolds have a different pattern. later heads have 2 rear bolt holes on heads for these. If you get an earllier set, they will fit. There is also different manifolds for drivers side or passenger side dipsticks.
    your right. I don't understand the jeep thing!
  3. Storm Trooper
    Nov 24, 2000
    4,640
    How close are they? Cast iron manifolds have a tendancy to warp when off for a while. When I had them (before headers) I had to clamp them apart to get them back on once.
    As for headers, make sure you know what heads you have before you order some. If you where closer, I have one brand new CI manifold I would sell cheap. good luck.
    [​IMG]<font color=red>Rid'in High In My K5[​IMG]
  4. shupach
    Dec 28, 2000
    648
    Dallas, TX
    the manifold fits somewhat, its just that the bolts are off some. Im goin to stop by the place i got the heads at and talk to them.
    phill
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the bolts miss the holes by just a fraction of an inch, it's the manifolds that have shifted a bit. Those things get HOT and over the years the internal stress of the cast iron gets relieved from all the heat. When you unbolt them, they change shape just slightly. With a bit of persuasion you can usually get them back in place. Just don't overdo it or you could crack the manifold. [​IMG]
  6. K10
    K10 Registered Member
    Feb 18, 2001
    52
    Rexburg, Idaho
    You can buy a spreader for a few bucks and it will spread it out so you can bolt it up.
    <A target="_blank" HREF=http://nick.rockcrawler.com>http://nick.rockcrawler.com</A>
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hehe, yeah, I've seen those things. Looks like a turn-buckle in reverse. Be careful though, you can break a manifold with one of those, especially if it is cold (like outside up north). I wonder if it would help to heat it to 100-200(f) in the oven before trying to spread it? Anyway, just don't try picking it up out of the snow with ambient at 10(f) and start cranking on it...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
