exhaust manifold?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Mar 28, 2001.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    My engine is sounding really loud lately. I smell exhaust coming from within the engine compartment and when I give it gas it gets louder. sounds like i have glass packs or something. is this serious? can it wait a while before getting fixed?
    baja surf nazi -...A late storm NEVER comes...
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    You have a exhaust leak somewhere. Try the manifold bolt's...TIghten them up.
    You can check out my rig right here <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Check that heat riser/stove thing on the passneger side manifold. Maybe it got disconnected. I'm sure if you had a small exhaust leak you would be saying something about a ticking noise.
    90K5
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    When my manifolds leaked it sounded like it was mentioned a ticking noise. Like when you were a kid and put playing cards in the spokes....unless it's making that noise I'd go with 90K5 said with the riser/stove......
    "I love the sound rice burners make when ya run over them"
  5. K5_73
    K5_73 Registered Member
    Feb 5, 2001
    53
    Wichita, Kansas
    Another common thing to check for is a crack in the manifold. The sound will be fairly noticeable just revving the motor, but should be way more pronounced with the motor under a load, like driving down the street. I say this because you said it sounded like you had glass packs, which to me would be little louder than a small leak like a gasket. If it is cracked, you should be able to spot it fairly easily. I hope this helps.
    Stupid hurts
  6. bigblue
    Dec 6, 2000
    658
    southern california
    Yeah, come to think about it, it sounds like a ticking noise. and under load it is louder. i will look during daylight and see, but i looked today and it was hard to see anything. sounds like it is coming from the right side....
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The right side small block exhaust manifolds are notorious for cracking. You can weld them, but they won't last...been there done that. Just bite the bullet and buy a new one from GM, about $140 or so. If you get a used one, it could only be a week away from cracking!! Good luck.
    ken
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 87's pass side manifold cracked and made noise like this. I would say cracked manifold.
  9. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    Depending on what you want to do w/ your rig, I would just go ahead and buy headers for it. For what you'll spend for a new manifold for one side, you can buy a good set of headers.Of course since your headers will come down a bit further than your manifolds, you will probably need to get some exhaust work done, especially if you want to run duals and don't already have them. Just something to keep in mind, compare the overall cash needs before you it, because you may be able to find a manifold cheap somewhere. Good luck.
    Stupid hurts
  10. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    Got the same problem but on the drivers side makes lots of ticking noise under load. Getting ready to pull it apart check to see if it is gasket or cracked. I will let you know. Jeff 80Blazer
    Its time to lock them in!
  11. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    Have you checked the donut between the manifold and the exhaust pipe?
  12. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I currently have crack in my RH exhaust manifold under the heat exchanger sheetmetal. I located it using a length of heater hose. Just put one end to your ear and use the other end to probe for the location of the sound. My leak is dead center under the sheetmetal. If you look closely at the PIC, you can see traces of exhaust coming out the left side of the sheetmetal.
    Good luck finding your leak. I'm picking up a replacement manifold for my truck this weekend.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  13. bigblue
    Dec 6, 2000
    658
    southern california
    It is funny. When she heats up she goes away but when cold it is pretty loud. I am going to get headers in the future but what do I have to worry about? I can live with the noise...it sounds kinda cool. Anything that can harm my truck with it being cracked??
  14. 80blazer
    Mar 4, 2001
    41
    glendale arizona
    If the crack gets bad enough and especially in cold weather on deceleration cold air can enter combustion chamber and warp valve. It is worth looking in to. Jeff 80Blazer
  15. Gandolf
    Aug 8, 2000
    764
    SF Bay Area
    Since the sound is louder when it's cold, and then gets quieter when it warms up, makes me 99% sure your exhaust manifold is cracked. Mine does the same thing. With the hot and cold cycling, the crack will get bigger. I first noticed the loud exhaust sound about a month ago. I drive my K5 daily and it has gotten twice as loud over the last 2 weeks. It is now approaching that embarrasing level which is why I am replacing mine this weekend. You could let yours go for a while, but don't expect it to last more than a few months. Also, keep a window cracked to keep fresh air circulating in your interior. Carbon Monoxide could be entering thru the firewall. You may smell some exhaust, but Carbon Monoxide by itself is odorless. The major symptom of Carbon Monoxide poisoning is getting tired or sleepy. Hope this helps you with your decision.
