exhaust/muffler options?
Discussion in '1982-Present GM Diesel' started by jp0863, Nov 5, 2004.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    the exhaust sucks on my cucv. looks like several places are dented in and the mufflers are shot (sounds like crap). what size exhaust tubing should i use for a little extra power and better sound? and what kind of mufflers should i use? i was considering glass packs only because they're small in diameter and probably wont get crunched on rocks as easily, but i'm not sure how they'll sound. anyone using glass packs?
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I run the Walker dual stock replacement pipes ( 2 1/4) into Flowmaster 40s. It is loud when on the gas hard but not to bad when cruising. This is on my tow rig so the stock low exhaust routing isn't a big worry. I know the flowmasters will take a beating as I run them on the jeep and the burban and both of those have been dragged in the rock fluantly. The ones on the suburban are dented up pretty good but no holes yet.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've ran dual 2.25" glass packs, dual 2.25" turbos, and currently dual 2.5" 40-series Flows.......I thought they all sounded pretty good and comparable to a gas big-block with the same mufflers (most people make the comment they didn't realize it was a diesel).
    The Flows sound the best for a pure performance sound, but are a little loud inside the cab with some resonation. I don't have any carpet or insulation in the cab and no tailpipes (just ends at the mufflers) which doesn't help, but it's a trail-only vehicle that gets trailered.
    The turbo's (Rino brand) had a nice deep sound and very little interior noise....that was with the thick factory insulation, carpert, and tailpipes.
    The glasspacks were okay, but the tone changed pretty quickly....I think the packing got sooted up by the diesel and it started sounding real raspy after about a year or so.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah glasspacks are made for gas which doesn't soot up as much.
    I knew a guy that made some glass packs for diesels, he made the holes much bigger so they don't get plugged up. His mufflers lasted as much as the non galvanized steel he used to make them. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  5. bigmatt
    bigmatt Registered Member
    Dec 4, 2003
    10
    Ann Arbor, MI
    I have 2 1/4 pipe to a pair of 40 series Flowmasters on my CUCV. It sounds pretty good. It is a little loud when you get on it, but not to bad crusing. Well, I can't hear the exhaust while crusing over all other noises.
  6. jp0863
    Aug 15, 2004
    566
    clovis, ca
    thanks for the input, i didnt think about the soot problem, but makes sense.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    It does sound good. If I didnt hear it start up... I would have bet money that it wasnt a diesel.
  8. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I run 3" exhaust pipe with a set of 70 series flowmasters. Just loud to sound tough and quiet enough to talk on a cell phone. Really sounds like a big block.
