Exhaust/muffler
Discussion in 'The Garage' started by paul86, Jun 20, 2005.
  1. paul86
    paul86 Newbie
    May 4, 2005
    Portland, Oregon
    what should I replace my stock 86 305 with....Flowmaster 70 or Magnaflow?
    Want to change from fron to back with new pipes/cat and muffler...no more than $500 though!
    It need to open up and have more power (yeah I know it's a 305)
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Actually it has been my experience that the 305 doesn't need much breathing. The PO of my '86 had duals with flowmaster 40s. I had to remove then and go with single exhaust for emissions. I put on a thrush turbo muffler and cat with 2 1/4" pipe and actually gained power, especially on the low end. Don't ask me why.
  3. wubba_65
    wubba_65 Registered Member
    Jun 22, 2005
    41
    Alberta, Canada
    Smaller engine is slightly higher reving (makes power at higher RPM) and the back pressure helps it make more power. Similar to how smaller 4 cyl engines with a turbo need to have a matched exhaust (but 4 cyl much more vulnerable to wrong combination than a bigger NA engine).
