exhaust out the hood?
Discussion in 'The Garage' started by 79mudder, Jan 14, 2007.
  1. 79mudder
    79mudder Registered Member
    Aug 25, 2006
    68
    Bonesteel
    i want to make mine go straight up and out. ive seen where they take a header flip it over and put like a 6 in round chrome tip on it , i think there called tight fit or block headers. searched on ebay and they want like 110.00 for them. and the pipes are like 50.00. so iam trying to figure out what regular exhaust manifold i can use upside down and with the exit go stright up. one guy told me to find ones that go on some 327 s. any one got any ideas.
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I dont have any idea but i sure want a pic of this when ur done.
  3. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    chrisblazzer89 the best way i can describe them is what they use on demolition derby cars. i dont know how you guys make where there is another site that you want to go to while you are reading apost and you click on it and it comes right up . i m kind of computer iliterate but if you search ebay under auto and search small block chevy headers demolition derby chrome . they are exactly what i want. or you can search demolition derby headers or tractor pull headers.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    why out the hood? so they can fill with rainwater?
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    your talkin about zoomies aint ya...there was a pic posted on here awhile ago, IIRC the guy had dual wheels from & rear and the thing was painted white.
  6. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    just buy header flanges and make your own, probably the easiest way possible... i think it looks cool with them straight out the wheel well...
  7. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    this what your talking about search for rock ape and you will find the rest
  8. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The manifolds you want were used by GM into the 70s. Rams horn, is what I call them. Look for early 70s trucks in salvage yard.:D
  9. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    those are the ones where the "collector" is in the center, as opposed to the back, correct?
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    dont use center dumps, you'll run into the MC. we've tried it before on derby trucks. block hugger headers do the same thing, so those are out too.
    the headers you see on Ebay, i'm assuming are these.
    i actually had to remove the power booster to get these to clear, and even then they BARELY cleared.
    what you need is a forward dump header...
    [​IMG][​IMG]
    www.decheaders.com expect to pay ~$150 for a set of headers in 1 1/2" with the proper forward offset though.
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    BTW the easy way to link a page is to copy the link in the address bar on top of the page and them past it on ur reply/write up
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    oh, and in stock mounts, they'll barely clear the hood...
  13. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Just an idea. Use the later rear dump manifolds, turn them over and swap sides, so the outlet is in the front.
  14. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    i put an ad on another site and a guy had just called me and said he custom makes them and he lives a hour and half from me cost is 115.00 he makes them 4 into 1 or as he called them corn rows like in the pictures of beater k20 iam going to get the 4 into 1 thanks for all the info. and its simple just cover them when it rais or put it in the shed.
  15. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    are you sure that this will give you enough backpressure to not burn your valves??? bc this is basically hte same as open headers and i though with that you will burn up your valves...
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    make DAMNED sure he'll make them to clear your booster/mc. the upward bend in them will have to be VERY tight in order to pull it off. unless you can talk him into forward dumps like i posted from DEC.
  17. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i like the staggared top turn outs from dec
  18. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    yeah i got alot of measureig to go over with him and to broncoman6524 s reply will it have anough back pressure so it wont burn up the valves? cause i see alot of mud trucks have them around here. i ll check back into this thread tomorrow after work.
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    we've got a couple sets that we run that are WAY shorter than those, and have yet to burn a valve.
  20. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I can already hear my neighbors calling the cops!
