exhaust popings sound
Discussion in 'The Garage' started by dheavychevy38, Apr 28, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    ok i have a 94 burban with a tbi 5.7 i recently acquired a poping sound out of the exhaust i think it is in the valve train. Any ideas or common problems with these motors anyone knows of thanks
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    When does it make the popping sound, is it all the time or only when cold?
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    all the time plus if you give it gas it back fires through the passenger side of the tbi
  4. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    It sounds like you have to adjust your valves.
  5. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    lotsa things can do it...
    Could be a valve problem,an exhaust valve might be burnt,or a valve spring broke,a lifter might have pumped up and is holding a valve open.,a broken rocker arm,bent pushrods,maybe a flat cam lobe--could be spark related too,timing off,bad plug wire,fouled plug,distibutor cap cracked,bad rotor,--also an air pump can cause backfiring if the diverter valve on it fails(not all trucks have AIR pumps)....time to get the tools out..good luck.. :crazy:
  6. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    thanks guys i am giveing it a full tune up and checking timeing on saturday i will also yank the valve covers and give it a look
