exhaust popping and sometimes back firing question
Discussion in 'The Garage' started by SF87K5, Oct 4, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Ok i replaced my carb yesterday thinking that was my problem. I cut off my muffler cuz it was all dented in. That did not fix the problem at all. My carb is adjusted good and the occasionally back fires and always makes a gargaling noise when I take my foot off the gas at 55+ mph. Also does the gargaling noise when I rev the engine and the RPMS are coming back down.
    Can someone please help. Thanks /forums/images/graemlins/thumb.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: exhaust gargaling and sometimes back firing question
    Gargling noise... That's the first time I've heard it called that, but it's a good description! Does it backfire or just make popping noises? My truck makes the gargling noise too, I think it's common with low restriction exhaust and headers, if you don't have headers then I have no idea...
  3. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I was screwing around with my timing the other day and mine started to gargle on the high way and would backfire so I retarted it a bit and it was fine. maybe check you timing?
  4. SF87K5
    Oct 27, 2002
    1,105
    Yeah I need to take it into the shop. I found out the the timing tab is gone. I dont not know how to do it by ear, so I have a friend that has his own shop. /forums/images/graemlins/thumb.gif
    Thanks for the help guys. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, you need to get a timing tab. Nobody can time an engine correctly without a light.
  6. SF87K5
    Oct 27, 2002
    1,105
    Well I found out my popping/back firing problem. There is this choke thing on the pass side on the exhaust manifold. Its vacuum operated, well there is no hose to it so it is closed off. This is to help the engine warm up faster, well I am just going to wire it open and leave it that way. I will let everyone know whats my out come in about 1 1/2 hours. /forums/images/graemlins/thumb.gif
  7. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Mine use to make the same noise, and I guess God fixed it, cause it went away on its own. Then a few months later, it has come back... I think it may have something to do with a bad distributer. Any suggestions??
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gifWhy is my truck in your avator?? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Mine has been doing that for a while too. Pretty much exact same discription. It sounds like a boat when it's idleing though.
    At Blazer Fest this year, Crawlin73 goes "dude, your rig sounds like a Mastercraft!" /forums/images/graemlins/rotfl.gif
    I'm interested in seeing where this one goes.
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    mine "gargles" too..Never a really LOUD pop, just light gargles...But I have accepted that it is b/c I am running SLIGHTLY rich and I have headers and DUAL 3" pipes with flowmaster 50's...
    Chris
  11. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Don't forget to let us know how this one goes /forums/images/graemlins/thumb.gif
  12. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    That has been a long 1 1/2 hrs. Do you think he died trying it? /forums/images/graemlins/tongue.gif
  13. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    ha ha ha... he's probably driving it all over the place b/c it worked!! /forums/images/graemlins/rotfl.gif
  14. SF87K5
    Oct 27, 2002
    1,105
    Ok it helped a lil but I think my timing and my distributer is f*ed up. It still poppes but not as loud. The good thing is no more back firing. I still have a dented Y pipe so I hope when I fix that friday it will help. I will let you know on friday before I goto uwharrie how it works. /forums/images/graemlins/thumb.gif
  15. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    well I am just going to wire it open and leave it that way. /forums/images/graemlins/thumb.gif
    does that mean you unplugged the unit? I haven't been able to check it out yet. Or does it mean you plugged up the hole?
  16. SF87K5
    Oct 27, 2002
    1,105
    There is a lil c-clip that holds the arm on it. I just took off the c-clip and opened it up and wired it that way.
  17. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    okay, so that arm that's hooked up to it goes in and out, right? Just left the arm hangin'?
    What hose is supposed to be plugged up to that anyway?
  18. SF87K5
    Oct 27, 2002
    1,105
    Just trace the hose thats off of it. Mine was already off so I dont know sorry. Also the lever thats on the pipe, the lilnub toward the engine.
