Exhaust Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cdh, May 7, 2002.
  1. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    I have a 89 Blazer with stock exhaust, and I am concerned about the crossover pipe that hangs below the transfer case skid plate. Every time I go off-road I smack the exhaust pipe on something. If I route the exhaust closer to the transfer case will it heat up the ATF fluid and screw up my transfer case? Thanks for the help!
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I built my own custom crossover to cure the problem. I used the Y pipe that came with my Thorley Headers and modified it to run under my rear drive shaft. I am also using the slip yoke eliminator so this may not work for you. I may also have some other pics if you need them.
    check out the pics at <a target="_blank" href=http://coloradok5.com/gallery/90k5blaze>coloradok5.com/gallery/90k5blaze</a>
