exhaust problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Apr 18, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    Whenever i hit my gas in park an rev up my engine, the exhaust starts making a popping sound, but only after i let go of the gas. I had my exhaust replaxed from the muffler back
    any ideas?
  2. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Had the same problem once. Turned out to be the spark plug cables that were rotten.
    "K5 Grand GT Blazer Silverado in the Netherlands."
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Does it sound like something is loose? Or is it a popping caused by the engine, as in backfire? If it's a backfire, it could be some ignition problem like bad timing.
    Hope this helps.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  4. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    Hey man mine does the same thing. I replaced all the wires and distrib. cap yad yad yad. Still did the same thing. But the check engine light was coming on at the same time. So I scanned the codes and it came up as the 02 sensor. Which I have not replaced yet because my exhaust is in such bad shape. But if your light is not coming on than maybe the timing is off a little bit. One little 1/16" can make a big difference. Hope this helped. Later LittleJimmy.....
  5. blazing86
    Dec 24, 2000
    290
    I know my timing is correct, i have had it set many of times recently. Also, this past summer replaced wires, and the whole distributer. Im prety sure i dont have an o2 sensor as well. My choke is still acting up some and i cant get thatproblem fixed. Could this be the reason for it? Or could it be spark plugs? ONe last idea..... could my exhaust be clogged somewhere?
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    are you running glasspacks? I've heard it's common to have a popping sound when it comes down (in the exhaust, not the engine). I had glasspacks on a truck and they did that.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    What muddin said
    90K5
  8. blazing86
    Dec 24, 2000
    290
    i have glass packs, but it was doing the same thing even before i got the new mufflers...........
