Exhaust question (Backpressure)
Discussion in 'The Garage' started by MTBLAZER89, Oct 22, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    This is for seventyK5. he is looking at the Baffles that I believe Summit sells that go onto the collector of a header. It says these will help with sound, but the question is will they create enough backpressure to keep from damaging the motor.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    As long as you have some kind of header or exhaust manifold you cant damage the motor or valves.
    Lack of Back pressure has absoultly nothing to do with motor damage.
    Excessive back pressure can cause damage.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Cool ok he was told something about when the air is very cold with no or very little exhaust cold air getting sucked back into the hot valves and damaging the motor /forums/images/graemlins/dunno.gif Not sure just want to make sure. This will only be temporary about a month until he can pay to get the rest done. /forums/images/graemlins/waytogo.gif
  4. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    The only time you really have to worry about that is if you are running No exhaust manifold or a very short head pipe. Running without a manifold will warp the valves. Because of the extreene temp difference.
    He should be fine with headers they are plenty long enough.
