exhaust question
Discussion in 'The Garage' started by adamforsythe, Mar 7, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    When I ordered my y-pipe, tail pipe, and center pipe I asked for a 2.5" pipes. When I started to test fit the pipes I notices that my tail-pipe was small. So I took a tape to it, it was 2" :mad: . So my question is should I return it and go through all of the crap. Or should I just by a reducers to bring my exhaust down to 2". I am thinking of taking it back. But I want to know what you guys think.
    Adam
  2. dyeager535
    26,979
    Been a lot of exhaust threads lately, I'm sure this one will get crazy too. :)
    From my understanding, and I'll be the first to admit there are a lot of variables that can affect this, the further back in an exhaust system you see a restriction, the less effect it has on performance. I believe the entire theory behind that is the heat shed through the system as the exhaust travels through the pipes. Still gains to be had, or cat back systems wouldn't be somewhat effective.
    2" single has to be really restrictive though.
    That said, 2" pipes look retarded. :p: I think the minimum for LOOKS should be 2.5".
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeh 2.5" if full length would be reccommended
    2" maybe if half length, maybe,..,
    depends on engine though,
    y pipe ? factory stock or aftermarket ?
    emissions inspections there ? or none ?
    if none then why not get stock dual pipes for pre-75 truck ?
    some of the 350/400 trucks had duals, i forget which all applications,
    good luck
