Exhaust question
Discussion in 'The Garage' started by Muddytazz, Nov 2, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What is the actual purpose of the crossover tube in dual exhaust and is it any better or worse than running true duals?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    It even out the pulses from the motor and is supposed to increase the scavenging effect.
    It is also supposed to make it sound better. IIRC
  3. bbengines
    bbengines Newbie
    Oct 18, 2005
    3
    ontario, canada
    Duals with crossover
    Ditto
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    DO a "H" pipe with chambered mufflers and a "X" with straight through design. Or so Ive read and been told. The X may make a couple more HP in the upper RPM over the H. Also listenning to newer cars, the H gives a deaper tone while the X gives a higher pitched sound. This weekend Im ditching my 4 cats and putting an off road H pipe on my 00 Mustang GT to go with Flowmaster Super 40 series and 2.5 inch mandrel bent pipes. You can get H and X pipe's from Summit and Jegs.
  5. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Magnaflow makes a tru-x you can weld in if you decided that route. Supposed to help with sound and the scavenging effect.
    On that mustang, I agree ditch the cats, but I would go magnaflow. Flowmasters with the x-pipe and no cats sounds like your dragging tin cans behind your car. Plenty of them around with it that setup, all sound like tin cans dragging. Magnaflow sounds REALLY good on the magnaflow and x-pipe, just my $.o2
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Not to Hijack the thread but...
    Im going H pipe with the Flows, sounds like it should... 60's muscle car. Well as much as can be with a OHC 4.6L.
    But definatelly do a crossover on any dual exhaust set up.
  7. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Adding a crossover dampens the sounds and increases torque.
  8. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I noticed a better sounds exhaust when I put my H pipe on.
    Headers, cats, H-pipe, muffler, tail pipes.
    Another thing I noticed is when I have my tail pipes off my truck is 100% louder. Why is this?
    ADam
  9. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    The length of pipe will quiet it down, as does the bends. Also where does it exit? If your mufflers are right behind your seat, and you take off pipes that exit at rear of truck then its exiting that much closer to you and louder.
